Leica LTM Double exposures?
EcoLeica
Check out my blog!!!
3:49 AM
Hey does anyone know if you can do double exposures with a leica IIIc? is it possible without wrecking the camera
Cheers
I thought I remembered the procedure, but I just checked it with my Leica IIIa and it still works. Take the first exposure in the normal manner. Then, hold down the release button while rotating the shutter speed dial counter clockwise until the selected speed is aligned with the index. The rotation should stop there. When that point is reached, release the shutter release button and you are set to make the second exposure.
Jim N.
