Drowned M8- Help requested
_goodtimez
12:07 PM
Hi all,
My sister is just back from a thanksgiving in NH. The horrible story is that she fell into non-salty water with her M8 and lens.
She relates there is condensation in the viewfinder and the lens, that she immediatly removed the battery, but now she does not know what to do or where to go with the camera.
Any advise is more than welcome.
Many thanks:bang:
Any of you remembers the guy who stripped an M8 down to the last screw, just to look ?
We would need to contact that guy.
Thanks
If it's fresh water and not too wet then there is a very faint hope for the camera/lens. B&H will almost certainly tell you to send the camera to Leica NJ.
BTW, therein lies the lesson as to why you should insure you camera gear. :angel:
If it were mine, I'd setup a room or area at a constant 30-35 RH and just let it sit for a week or two. Then plug the battery and card back in and use it.
A waste of time asking B&H what to do, they'll just say take it to Leica. won't they?
Be pro-active, dry it out and see if it works before running around in circles.
Steve
Turn on the heater in the bathroom and the ventilation to get some air flow, let it dry for a couple days. If she didn't turn it on while it was wet, it might be fine. B&H won't be much help, Leica NJ will replace the entire M8 down to the last screw if you feel like paying for it. I probably won't need that but water damage has never been cheap. Hopefully it didn't get into the electronic compartments or corroded anything.
Breaking news:
She left it to dry near a warm source and a fan. There are water stains inside the veiwfinder but no more humidity. She powered it and it works, apart from the rear control wheel which is for the time being plugged with mud.
Thanks to all of you for your help. I will come back to this thread to feedback more information when I receive it.
I advised my sister to ship it to me so I can partially strip it, we'll see.
I think it will survive. Electronics boards and chips are subject to much harsher chemicals and temperatures than exposure to lake or river water when they manufactured and assembled. The rest of it just needs drying out (ASAP).
Can you get hold of a portable airconditioner? I would have rigged up a box - or small room - and then put it on de-humidify. Also put in a source for heat, and you will have the perfect conditions for drying it out.
If it works now, it will probably be fine - but you need to really get all the small drops out. Dry, hot air will probably do it - preferably way longer than you think is necessary.
Later on there might be some problems with contacts and so on, but the chance gets less with a thorough drying out.
One never knows about electronics. My wife's cell phone went through the washer and dryer successfully. The trip it took under the car tire cracked the display but still left it working. For both incidents it is fortunate that her ear wasn't attached to the phone as it normally is.
Good luck with the camera. Double check the cleanliness of the sensor!
I would never trust a digital camera that had been dunked in water until it was professionally serviced. Besides, there is the chance things are rusting and corroding inside as time progresses. Sounds like false economy to me not to send it for repair. Must not be very important to the owner.
