Dry down % for Ilford MG IV Matt
Henk
11:27 AM
Hello,
Has anyone tested Ilford MG IV Matt for dry down percentage ?
If yes what were your results ?
Thanks !
Tested
Tested
If anyone should be interested, I did test it and found -10% as the result
for Ilford MG IV FB Matt paper.
10% sounds right to me too. Usually if it looks just a bit too light and too contrasty wet, then it will dry perfect.
BTW - does anyone else find the Matte to be less contrasty and dense than the MG Warmtone semi-matt? I wish Ilford made the MGIV Matt as dense and contrasty as the WT semi-matt. I don't like the warm tone reddish hue even with Dektol 1:2.
>I wish Ilford made the MGIV Matt as dense and contrasty as the WT >semi-matt.
The emulsion and base are the same between Ilford MGW surfaces - the difference in apparent contrast and maximum black between the surfaces are caused by differences in reflectivity, not differences in the manufacture of the emulsion or the base. You need to change your printing to compensate.
Marty
Yep, Matt is harder to print, but a well printed matt fiber paper is, in my
opinion the most beautiful wet print there is. Again, this is only
my taste :)
