Early Nikon F2, Differences in Construction.
Sonnar Brian
Product of the Fifties
Staff member
7:30 AM
I picked up two very early Nikon F2 Photomics at separate camera shows, SN under 7101500. I noticed they "did not seem the same" but could not put a finger on it at the show. They were cheap, and I never pass on a cheap F2.
After sitting them next to a late F2, some of the differences started to surface. The biggest difference, the shaped Tip for the film advance is metal. Then started to notice: no steel insert for the strap lugs, flathead screws, and one F2 had a white stripe around the self-timer.
Pictures speak louder than words.
My pair of '71 F2 cameras.
picture.php
Flathead screws:
picture.php
picture.php
No Steel Inserts:
picture.php
On either body, either side.
picture.php
Underside of the Metal film advance tip is round at the seam.
picture.php
The tip is metal
picture.php
White stripe, not red, at self timer and the grain on the leatherette is like a Nikon F, rather the later F2.
picture.php
Height on the Advance Lever is just a little lower than the 72 F2.
picture.php
DP-1 SN, I'm guessing they started at 200,000.
picture.php
Next up is a 72 block F2.
Steel Inserts on Strap Lugs, and grain on Leatherette has changed, advance tip is plastic. Although, it is easier to feel the difference when touching it- the metal tip feels colder.
picture.php
picture.php
Phillips head SCrews.
picture.php
Bottom of tip is squared
picture.php
Advance Lever Height.
picture.php
Very cool stuff Brian. I never knew there was any difference in F2s. Makes one wonder about the F3 too.
Thanks dude!
B2 (;->
I'll have to check on the F3. Somewhere at work, the one I bought in '82 is still around. I have two late ones, at the 2M mark. Also have a 1983 F3AF- but it does not count...
Thanks for those photos Brian. I'd not realised that the shaped tip on earlier ones was painted metal. My early one has the slotted screws and old style F leatherette but has the later winder etc.
Another difference that is seen in the early F2 bodies is the mirror lock function. The original design simply required that you rotate the lock lever counter clockwise. When the MD-1 motor finally began shipping and real photographers began using it in the real world, Nikon found this to be a flawed design. Fingers wrapping around the grip would occasionally partially operate the mirror lock lever resulting in out of focus images and sometimes a jammed camera. It was quickly redesigned so that you had to press inwards firmly before you could rotate the level.
The OP's pic that shows the bottom of the mirror lock lever seems to show the early design as the lever seems tight to the body, lacking the space present in the later push-and-turn design.
Brian, unless my eyes are failing me, your third picture seems to indicate that early F2s may have had the slightly-glossy black finish of an F-style shutter speed dial insert, whereas the later F2s insert is more of a matte finish.. of course, i'm about a cup short on coffee this morning, so i might be imagining things. :)
I just checked, both observations are correct.
1) The Mirror Lock-Up turns without pressing the DOF preview
2) The Shutter Speed Dial is the older Glossy Finish, not Matte Finish as on my '74 block F2.
I have an MD-1. but never use it on the older F2 bodies. The early bodies are reputed to have a backlash when used with the motor, causing the frame spacing to be irregular. By the '73 block, this problem was said to be corrected.
ai
ai
interesting thread. i have been considering purchasing an f2 as well.
i'm wondering if non ai lenses meter on the f2?
i like the older lenses with the scalloped focusing rings.
i read something about stopped down metering, but i'm not clear on
this.
can you clarify the usage of the older lenses, & or the ai type?
thanks,
The Nikon F2 Photomic (DP-1 head, as shown here), F2S (DP-2 head), and F2Sb (DP-3 head) all meter with the older non-AI style lenses. The DP-3 head is the equal of the F2AS, and meters down to EV-2. It uses Silicon Photo-Diodes, and is the most advanced meter for the Non-AI lenses available. All of the others use CDS cells. The DP-2 head is the least reliable. The later DP-1 heads, with an extended cutout for the meter (~1975) are the most practical and lower cost.
f2
f2
i see. i suppose with the dp 11, or 12 one could have an earlier lens
converted to ai. might be expensive.
"In the Day", Nikon charged $15 for the conversion and put a new aperture ring on it. These days, conversion kits for most lenses are used up. You can file the existing aperture ring.
This is some valuable information you've given concerning the F2's. I have two - needed the extra for b&w film, and I love them dearly. I haven't switched to digital yet and I don't have any immediate plans to do so. Guess I'm stuck on film and my F2's. Thanks for sharing the information.
ah, such feast for the eyes! looking at all this detail--time and decay are curious things: horrifying, beautiful...
my F2 boxes get some healthy exercise daily, unlike the closet queen M3 :cool:
by the way, brian, what are these ring-bound books in the background?
The Ring Bound Books are the Nikon/Nikkormat manuals, circa 1972. They are by Abbott and Cooper. Great resources. These include the original announcement and supplement for the F2. Picked them up in a thrift store, the owner knew me and set them aside.
The computer manuals for the 8080, Z80, and Microsoft: also from the 1970s. I bought those new...
thanks. now i get it. after the first shot of obviously F2 material, i couldn't quite fit in the data bus stuff ;)
(the wettest of all wet dreams: F2 with the D3X sensor! :p)
