Ecn 2 help
Cabledog
5:49 AM
So I got some 120 and 35mm vision 3 500t to develop but I've read that it really should be done in ecn2 process and not c41. Aside from the remjet issue I'm having trouble finding any info on where to get cd3 and other chemicals needed for ecn2. Someone had mentioned RA-4 in lieu of CD3. Anyone have any info to help??
I finding ecn 2 in c-41 to be better. ECN2 is weird looking film, even D, any way.
Interesting. I read c41 causes some strange color shifts and little more grain. Guess I'll try in c41 and see what happens.
I'm not wet printing. Thanks for the link! I'm going to try the ra4. If I read that correctly then all I'm changing is the developer and using the regular Blix and stabilizer per same times I do for c41?
Don't know the correct answer as I only tried it once with the dilution recommended for RA4 paper (1+4?) and this dilution at 3:15 and 38deg gave me a negative that was clearly overdeveloped.
