3 Day Fix Test....
3 Day Fix Test....
Okay, to recap, earlier in this thread, some were wondering if their negatives were being harmed by fixing times running longer than the minimum necessary times, so instead of 8 minutes fixing time (my usual), I left a 4x5 negative as well as a print in fixer for 3 bloody days to see if anything would be left of them. I made a contact print of the negative before and after. Here is a single scan of the two contact sheets:
Ignore the dust. I think there is some minimal but still noticeable loss of density, but I'm not sure if it's within repeatable tolerances, slightly more exhausted paper developer, etc.
I think I need to dunk the negative and leave it for a lot longer (like a month) to see at least a one stop difference between contact prints to be sure.
The paper print that also spent three days in the fixer tray also seems just the same as when I first dunked it, but that's a subjective assessment.
I think that for all intents and purposes, there should be no practical discernable difference with fixing times running 10 times what your normal times are, and any loss of density comes after days.
So if you are worried, you can relax.
Full disclosure: Ilford Rapid Fixer, mixed up fresh about a week ago, contact sheets, 3 days apart, height locked, aperture locked, digitally controlled exposure time (my standard 90mm, f/8, 30 second contact print exposure). Film negative was underexposed by a stop, therefore expendible, and it was a little dustier the second time around (my sloppiness).
