Efke KB25 now blue?
alfredian
5:41 AM
Maryland, USA
I just opened my first bulk roll of Efke KB25 in 2+ years. The backing is now blue - reminds me of the 2 rolls of Fomapan 120 I tried out 5 years ago. The last batch of KB25 was grey-over-grey. Is this just a different base material? It also feels a bit thinner than the older base. I have all my parameters (exposure, development) settled for the emulsion, so I hope that is still the same. Any clues as to when Fotokemika changed their product?
Thanks for helping me realize what I found so curious about my last two rolls of Efke 25. Last fall I exposed a grey one, now they were blue... no preceived change in emulsion properties though, so I think it's just the base material...
Thanks, what I'd hoped
Thanks for the reply. I'd hoped that's all it was - somebody at Efke using the same base-supplier or (I suspect) at least the same anti-halation coating that Foma uses. I'll shoot a test roll just the same. Aside from the grain & accutance, I do like the ortho-pan spectral response of KB25.
If you're using Rodinal and really bored then presoak and pour the blue into a clear container. When developing is over then pour the Rodinal into the presoak...blue will instantly turn to green 😀 Atleast it did that one time I was very bored.
Thanks, all
Thanks, all
Shows one downside of buying in bulk - keeps you out of the market for long spells. My first 100' of KB25 was US$30 in 2005 or so. Cream emulsion on light-grey backing. Developed in D76 1+3 outwash of the dyes wasn't evident. Ditto my first 2-3 ten-packs of R25 in 120. I dimly recall somebody blogging about halation issues in contrasty light, back when. At least the Arista Premium 100 I loaded up at the same time today looks like (dare I say?) Plus-X.
the Rollei Pan 25 is a very dark blue. I have not done a presoak with it so I can't say how that comes out but I will try it on my next roll. The Rollei is made by MACO. The thing I don't like about Rollei is they are using the Rollei camera name and running off that old reputation. The film is great though.
All the Rollei film I have says "Made in Germany", but I could have swore I read that it was made in Croatia.
Corporate fragmentation
I suspect we're seeing several corporate amoebas in motion here. FSU breaks up, Agfa breaks up, and various outfits buy up trade-names, product formulas, and finally the gizmos that actually coat films. I used to see this in the food industry - to wring value out of a factory, they'd do one shift of their own brand, then put the same stuff into the same cans, but with another label. After midnight they'd actually change the recipe & go totally generic. Now somebody with rights to "Adox" is labeling up Efke film & jugging up the modern formula of Rodinal. Keeps us on our toes. My personal favorite is when they put the wrong film-type-brand on the edge-print & sellers have to tell you what it "really" is.
Efke KB25 is my favorite 35mm film. With Rodinal and good exposure technique, the resulting negatives have that wide tonal range of medium-format, If you want a little grain for texture, use 1:25 Rodinal with vigorous agitation. Lovely stuff, hope they leave it alone.
RO9 is good, too
RO9 is good, too
Mine, too, if there's enough light, which there usually is. Otherwise I use my "fast" film, Plus-X. I still miss Panatomic-X at ASA32. I do the KB25 in Fomadon RO9 1+40 for 6 minutes x 20'C. Usually. Sometimes I do use the D76 1+3 for ten min, which is a bit less aggressive than the RO. Then again, I have to have the ambition to mix up the 76 from powder, etc. I expect to spend my retirement years (over a decade away) coating old bits of window glass with emulsion from a jar. Get an M-mount or LTM adapter for a view camera, most likely.
Efke (Fotokemika) in Croatia changed their base in 35mm two years ago to Blue Polyester. In the past it was Grey Tri-Acetate. However their emulsion has not been changed.
Rollei films are 80% made by (Agfa) Gevaert in Belgium and some emulsions by Filmotec (former OrWo). Confectioning in 120 roll film can be done by Efke, Foma or even Harman/Ilford. 35mm is done in Bergheim, Germany by Photostar.
