Other/Uncategorized Elmar F3.5 50mm lens step up ring?
Other Screw mount bodies/lenses
Won't work, the Elmar has a filter ring around the lens and it's 19mm only. The 36 is the outer diameter but it does not have a filter ring there, the 36mm filters are 'A', meaning 'Aufsteck', translates to 'clip on' in English...
You can PM me if you want, I have a few filter that I never use...
I thought that some Elmar's at least had a 34mm thread on them. There are plenty of 34mm step rings around, and even some 34mm filters - maybe I am wrong!
