ELMARIT-M 28mm f/2.8 ASPH vs summaron 5.6?
hrryxgg
10:58 AM
i have the elmarit and thinking about switching to the summaron.
i like the compactness of it.
i wonder how much i'd lose by having 5.6 vs 2.8 range?
anyone have both or thoughts on this?
thanks
Use the lens you have with aperture not larger than f5.6. This will tell you like nobody else.
But. 🙂...
I had 28 2.8 and I had 28 5.6 RF lenses. On digital M it was difference between no flash or flash indoors. But if it was static objects and high ISO I was able to still use f5.6 one indoors.
On the street and with film M I needed f2.8 with ISO 50 films and then sun was down, but light still coming. With f5.6 I have to quit maybe half an hour earlier. I like to not go bellow 1/250.
After sun was kaput I have to switch to 1/8 with f2.8 lens and push my ISO400 film.
f5.6 was no go lens for dark time of the year.
I have now huge 28 1.9 and thinking of getting 28 5.6 again. But not Leica one, again 🙂.
thanks
For me the Summaron-M would not replace the Elmarit-M asph.
I have the two 28mm lenses (also some others...), for more than one year the Summaron-M 28mm but in everyday use Elmarit-M asph. is as good as can be a 28mm lens at all aperture.
The only time that the Summaron is superior (in my view) is when used at night pictures with spot light in field : at f/5.6 no stars on spots with dof of 5.6 and no coma to speak of.
28mm Summaron-M is a special lens for special occasions with flaws for modern concepts: flare a bit more, focus only to 1m, when I don't take care I have my finger in the pic 😛 because it's so small and don't use the huge hood (that "doubles" it's weight), difficult to use a filter rare size E34!
28mm Elmarit-M asph. is all around good lens with no flaw by modern standard.
Not much gain in weight for the two 28mm:
Summaron-M (mine no hood) 164g
Elmarit-M asph. (version I, no hood) 178g
Use the lens you have with aperture not larger than f5.6. This will tell you like nobody else. . . .
Indeed. Consciously noting how often you use large apertures will tell you how much you use them. In my case, the answer is "a lot". That's why I got rid of my 35 Summicron. By f/5.6 the difference between it and the Summilux was not worth worrying about; at f/2, f/2.8 and f/4 the Summicron was better; but at f/1.4 there is no contest...
Also, I once had a 28/6.3. Quality was so-so, but the absurdly small maximum aperture was the main reason I got rid of it.
Another thing that I didn't mention:
Summaron-M with Digital M is very nice compact/handsome combo special with M-D or Monochrom and when ISO required 3200 or more can be used without fear.
As I recall, Summaron-M 28mm was made on request so it's not easy to obtain one from the shelf.
Have-you seen this RFF thread : https://www.rangefinderforum.com/forums/showthread.php?t=159408
thanks
It's only compact if you don't use the lens hood.
I have the Elmarit asph 6 bit (like that matters on film!) and it really is a perfect lens. I have not seen anything I like from the Summaron, if anyone else made it, it would have been royally panned. The way the Lomo 32mm 2.8 Minitar has been (which I have). But that lens is sorta cheap.
Anyway, as I am primarily a film shooter, a max aperture of 5.6 is useless to me the moment the sun starts to drop.
...only compact if you don't use the lens hood........ I have not seen anything I like from the Summaron, if anyone else made it, it would have been royally panned........
I agree entirely. Leica could have brought out a slow, compact, fabulously corrected 28mm lens which some of us would have craved. Instead they opted for a heritage design with mushy corners and an agricultural hopper for a lens shade. I think they were lazy. It's a pity Zeiss aren't in the market to release a 28mm f5.6 that sings, bites, and shouts crikey with each exposure.
........... Chris
