TXForester
I'm thinking about a way to keep the sensor in cameras cool during long exposures. Sensor heating is one of the sources of noise (that grainy look) that can be controlled to some extent. The easiest way to deal with it is do night time land/starscapes when the ambient tempts drop the temperature of the camera body, but that doesn't help during summer.
A cheap solution to summer temps is encase the camera in a modified cooler and put ice packs in with the camera. A high tech method is modify a cooler with Peltier cooling using a thermo-electric cooler (TEC). You can buy a cooler with a TEC system designed for keeping sodas and snacks cool on long drives, and modify it to fit the camera. You can buy a TEC and buy/make a cooler and put them together.
The common problem with the high and low tech methods is condensation. Condensation and electronics do not go well together. I think a venting system could help, but it would keep the system from reaching it's lowest temp for the camera body. Probably not bad if I can drop the body temp 15 to 20 degrees F. I could be wrong. To vent air from the cooler means warmer, water laden, air from outside would come in to replace it.
Any other ideas on eliminating or minimizing condensation?
