Enlarger focussing issues
esc_ctrl
8:49 AM
I am using a Kaiser VPM6002 enlarger with a Rodenstock 50mm lens and have the following problem:
when printing larger sizes (above 18x24) I have to turn the focusing knob all the way up until it stops and the bellows is completely collapsed. I can't get it 100% in focus then. There is always a little tad missing.
18x24 and below is no problem, there is still a little leeway upwards and I can focus properly.
Anybody know what the problem could be?
I have a meota and it has a lens holder that can be used concave or convex , when used concave the bellows do not have to be compressed so much , I think this is what you may need . Or you may be able to turn your lens holder upside down.
Thought I would mention, I have two lenses. One is for 35mm negatives and the other for medium format negatives. If I try to use the medium format lens with 35mm negatives, I need to move the head way up just for an 8x10 print and I hsve focusing issues. I use an Omega B-22 XL.
I'm not in my darkroom. I can go take a look at the lenses to give you specifics if you need the information.
There is probably a recessed lens board for 50 mm lenses. You might have to make one.
Lens longer than 50 will require greater focus distance given the same size print . A bigger neg will equalize the distance partially
Printing 18 x 24 = probably a medium format negative. Bill Clark is on the right track. You'll need a 75mm or 80mm lens for 6x6 negs.
Thanks for the hints! I will have a look at the lens mount and see!
I am talking about 35mm. For 6x6 I have a 90mm lens. No issues there.
I will keep you informed
