Enlarging lens Visoflex III and M9
SDK
Exposing since 1969.
1:43 PM
Hi folks, I recently got an M9p and have a Visoflex III on the way. I’m getting an Elmar 65mm and 16464K focus mount adapter too, which should be fun for starters. I have some nice enlarging lenses with M39 screw mounts I would also like to try for macro work (50mm/2.8 Apo Rodagon N, 63mm/2.8 EL Nikkor, 80mm/4 Componon S, 105mm/5.6 and 135mm/5.6 Rodagons). Is there an adapter I can get to use these with the 16464K or some other focus mount?
Any advice would be appreciated.
If they are narrow enough for about1.5 cm youcan use the universal Schnecke OTZFO
Thanks Jaapv and Roger, I’m getting an OTZFO (16464K), but I suspect most of the enlarging lenses are too fat to fit inside, being c. 40-45mm diameter. So I’ve found some Leitz extension tubes on eBay that I hope will fit and allow the lenses to work. I think I’d rather use tubes than a bellows.
The Leitz bellows really is very nice, and extremely easy to use. I much prefer it to extension tubes (and I have both).
