Ensign 12/20 med format folder.
SCOTFORTHLAD
Slow learner,but keen!
11:26 PM
UK.
Does anyone have any experience of this 6X6 M/F folding camera.It is British,dates from the 50's,and carries a Ross Xpres 75mm lens.Any comments gratefully received.
Brian.
I have the 6x9 version with 105mm Ross Expres lens. (for sale) I've found the lens to be very sharp. The camera is well-guilt and heavy compared to a Voightlander Bessa 6x9 folder. (also for sale) Mine are scale-focused and use a red window in the back door to advance film to the proper point. What else would you like to know?
I have an 8/20 with the epsilon shutter and it was my father's before that. I have never had a problem with it although it has been serviced once in it's life.
Kim
Thanks everyone for the comments.I had been aware of Ensign Selfix folders for some time,but in their 6x9 and 6x4.5 versions,similarly I had read that Ross Xpress lenses had a very high reputation.However for some reason I was unaware that Ensign also produced the 12/20,which resembles in appearance the Isolette and Nettar 6x6 folders ,but has a pop-up viewfinder rather than the built-in type.I've seen a couple advertised recently and been surprised.
I have often hankered after this type of camera,and a British version would be nice to own at some stage,but being unaware of the model,I wondered if for some reason it was not as successful or as reliable as it's larger cousins.Also the Epsilon shutter is not too common,but as Ensign used it on other
models,presumably it has some merit.
If any one has any more insight,would be glad to hear.
Cheers,🙂
Brian.
