EVF or no EVF
jett
9:22 PM
I'm interested in an M43 but I'm not sure if an external electronic viewfinder is worthwhile.
I don't plan on manual focusing much because it is my snapshot camera but I feel that composing with a viewfinder would be more enjoyable; however, the viewfinders are generally not-so-good and expensive, so maybe they aren't worthwhile.
For those that have an M43/Nex/whatever, do you like using the EVF? Is it worthwhile, to you?
I just bought one for my Nex 5n. It makes it usable in bright light but I could live without one, LCD on nex is really good...
Absolutely worth it.
I was in your situation thinking they were too expensive, but I got one. Now I'm glad I did. It makes it so much better to use especially in the bright sun.
Definitely go for one.
Worth it for bright light benefits, and especially so for manual focus lenses. If I shot nothing but AF on a 4/3 especially if it had stabilization... I might consider skipping the EVF.
As it is the EVF is mounted on my GXR about 50% of the time, sometimes more, sometimes less, depending on subject. I shoot nothing but manual focus lenses on it.
I use an E-PL2 with a trio of native micro four thirds lenses (17mm oly, 14-42mm oly, and 20mm panasonic). I also own an VF-2 EVF unit, which is very, very good (look through one in store and tell me it's "not very good"), but honestly, I rarely use it, unless I've got one of my manual-focus Nikon, Pentax, or Leica lenses mounted; the benefits to manual focusing and using longer lenses is undeniable (higher res, plus you have one more point of contact to stabilise a longer lens).
Consider this: an LCD screen frees the camera from being stuck to your face, and you have additional creative freedom to shoot higher or lower than your normal eye-level. This is a benefit. You are also free from tunnel-vision, and can quickly switch back and forth between your LCD screen and the scene you're trying to frame, in order to be more aware of things entering and exiting your frame.
I will respect those who feel using an eye-level finder makes you feel more like you're using a "real" camera, but seriously, are Hassleblads and Rolleis not "real cameras" because they lack standard eye-level finders? If you feel that you shoot better with a camera stuck to your face, then that's fine and quite valid. I mean, if you've shot with SLRs and rangefinders your whole life, that sort of shooting style might just feel "right" and automatic. Otherwise, keep an open mind. I find that too often, the underlying reason is that some people feel they don't look like a "serious" photographer with a camera held out at arm's length.
Another member here, Don - a street photographer, swears by the unhitched view you get, like a window on the world, without an optical or electronic viewfinder stuck to your eye.
I must admit, I didn't believe I could adapt to shooting that way but thanks to Don's enthusiasm I tried it and found that it was a very useful way of looking at the world and the subject of interest within it. In some ways it is similar to how one perceives more than just the framelines when using a rangefinder camera.
Optional EVFs being, well, optional, you can always add them later to your system.
On my G1 I always use the EVF, never the LCD. I use only manual lenses. It's sharper for focusing, brighter, more precise feeling, and is unaffected by glare. My daughter switched from an LCD point and shoot to her own G1 with the native lens, and I noticed that after using the LCD for a few days, she switched on her own to the EVF. She's a prolific picture taker too.
Personally, looking around or moving the entire camera body when using an LCD to see the scene is a lot slower for me than opening both eyes in a viewfinder.
This info is very useful to me. I have a G1 and am considering an EP2 w/EVF2. I have 2 other compacts, but both have lcd & ovf. I also have a Sony R1, and with it's unique lcd, I can use at eye level with evf or as wlf with lcd. In bright sun, all my lcd's wash out, so am forced to use ovf (very small) or evf's (OK).
Does anyone have a direct comparison between the G1 evf and the Oly EVF2? I use both AF & manual focus lenses.
I have a GF1 with the EVF. I am going to replace it with one of the newer 4/3's but I will still buy the EVF. Holding a camera out in front of you to compose is just a dumb way of trying to get a good picture. You just add camera shake with arms extended and no amount of image stabilization is going to correct it. EVF is essential for serious picture taking. An optical viewfinder on the hot shoe is a good alternative, but you lose parallax correction and accurate framing.
And I haven't even commented on the poor performance of the LCD's in bright light.
Worth it. If only for the more stable "handholding" position where you can brace the camera against your forehead. Don't get me started on camera designers who think that the way to high IQ is holding out your arms like a photo-zombie. Rrrrrrr. . . . brains.
Thanks!
I wasn't sure if it was worthwhile, to me, since it kind of defeats the purpose of a compact camera (to my standards, atleast). I felt that if I were to only use the EVF then I might as well get a Panasonic G or even a DSLR, but the great thing is that I'd have a choice. I can see the virtue of shooting both ways.
Unfortunately I won't be pursuing one anytime soon because my old laptop monitor/screen is having problems which means that I need a new computer instead of another camera.
I have an E-P1 and I mostly regret to not have gotten the E-P2 for the possibility to add the EVF.
Re.: defeating the purpose of a pocket-able with an EVF. The EVF is removable. When I walk around, the camera is either in my hand or pocket and the EVF is also in another pocket.
When I want to shoot, it slips on and away I go. Sounds awkward? Well if your camera is in your pocket, your not ready to shoot anyway, right?
I use mine all the time on my Panasonic GF2. I can't get used to the idea of composing on a screen on the back of the camera. I know that people say "not so good," but if you're using AF lenses then it's a viewfinder rather than a focusing device. (For focusing things like Leica lenses, I'd rather have one of the newer cameras like the Sony or better yet the Ricoh, for the focus assistance devices they have.)
Tom
I've got an E-P3, and I planned on getting the VF-2 right away.
That was in August. Still haven't gotten it.
In general I think I do prefer having an eye level finder, and catch myself putting the camera up to my face once in awhile, but the screen on the back has been good enough that I haven't really NEEDED the finder in most situations.
If I had ANY of the other olympus's I would have gotten the finder already though. The E-P3 screen is really that much better than the others- bigger/brighter/easier to see.
-Brian
I've had a G1 since just after they were introduced. The EVF is a little disconcerting when you first look through it if all you've used in the past has been optical viewfinders and SLRs. But you quickly realize how useful it can be and you adapt to the way the image looks.
I still prefer the clear, unobstructed view of optical viewfinders. I use accessory OVFs with my E-P1 and E-P2 cameras with 17mm and 25mm lenses. I just bought the EVF for the E-P2 and I'm beginning to like using it, especially with zooms.
If you can hold out for another month seriously consider the Olympus E-M5.
The EVF is built in and everything else about the camera looks top notch.
The hotshot EVFs on the pen style cameras just stick up too much and are easily knocked - I hate them.
