anselwannab
Is there an eyecup for the CL? I have glasses and some cameras with out some rubber back that end up nicking my glasses over time. Just want something small, more of a bumper than anything so it doesn't back me too much to see the meter and Shutter speed.
I didn't see any ridges for something to hold onto.
THX
THX
panerai
I would suggest trying some medium foam or dense acoustic foam. Cut it to shape and fit.
Check the foam to make sure it's not too hard
Can buy self adhesive foam and just cut to fit the frame of the eyepiece and stick in place to act as a buffer
Other foam. Small bead of glue around the frame to hold in place
DON
DON
anselwannab
Great idea, I was looking for someway to mechanically a fix it, but there are no ridges. The adhesive is a good idea.
zuikologist
The softer side of self-adhesive Velcro strip cut to size works well. It is cheap and you may already have some at home.
B-9
Devin Bro
Doulbe the suggestion for the softer side of a velcro kit.
You should be able to get 3ft for 1.50$ at any Wal Mart store.
Ive used this extensively as a lightseal material, cant go wrong.
pingu666
if your left eye focuser then the hotshoe area is quite sharp so that might be another area to cover
