Dracotype
Hold still, you're moving
What was the "standard" lens for the Fed 3? I am bidding on this camera. Just wondered if anybody had any confirmation on the lens and such. He says it is a Fed 3, but when I consulted Cameraquest.com's camera profiles, the only Fed 3 with a lever film advance is the Fed 3 L. Thanks.
Drew
Drew
L
Laika
Guest
Dracotype said:What was the "standard" lens for the Fed 3? I am bidding on this camera.
As far as I know the first FED3's had the Ind-26m lens (what you have) and the later models had the Ind-61 and the last of them the Ind-61 L/D
Dracotype said:Just wondered if anybody had any confirmation on the lens and such. He says it is a Fed 3, but when I consulted Cameraquest.com's camera profiles, the only Fed 3 with a lever film advance is the Fed 3 L. Thanks. Drew
The FED3 are broken down into two versions, the FED3a has a knurled knob style winder and the later and more common FED3b has the thumb lever winder (what you have).
Edit: I've added a picture of both of the early "a" types, the one on the left is the first "a" and in the later "a" the logo was changed to the dual type, the speed selector is a little different as well. (note: The right camera has a Jupiter 8 lens, these were never standard on FED cameras.)
Have a look over this web site, the intro section gives a good overview of the different FED & Zorki models ... http://www.geocities.com/fzorkis/index.html
claidemore
claidemore
Here's a couple other links with a good info on various Fed models.
http://www.commiecameras.com/sov/35mmrangefindercameras/cameras/fed/index.htm
http://jay.fedka.com/
http://www.russianplaza.com/FED-1-2-3-4-5-C-page2.html
I have a Fed 3b with the lever wind and I-61 lens which I like very much. I've been looking at the Fed 3a's for a while now, and just might spend some of my 'Ralph bucks" (little Alberta joke) on one in the near future.
I did read somewhere that both the I-61 and I-61 L/D lenses have lanthanum in the lens elements, but they just didn't indicate it on the early ones.
Glen
Glen
