Fed Sizes
holgaguy
11:41 PM
Monterey, Ca
Hi, So are the different Fed modles different sizes. If so which is the smallest up to the largest ? Is the Fed 1 smaller than the Fed 2 or 3 ?
And size wise how to they compair to the other FSU barnds ?
Thanks
holgaguy
FED 1/Zorki 1 are the smallest by a reasonable margin. FED 2 is wider but only a shade taller. All other FEDs and Zorkis are about the same, being taller and a little wider. FED 4 and 5 are the largest (tallest). It's surprising how little they vary, other than the FED 1/Zorki 1. They do *appear* quite different but side-by-side there's not much in it - that includes the Kievs.
As has been mentioned, the FED-1/Zorki-1 are the smallest. Then FED-2 up to FED-5 share the same body and differ only in height: FED-2 is the lowest, then FED-3, FED-5 and the tallest is FED-4.
Zorki-3 and 4 share the same body, and then Z-5 is a bottom loader and Z-6 has hinged back, but they (Z-5 and Z-6) are almost the same size.
