Leica LTM FILCA variations
Scrambler
11:46 AM
Toowoomba
I just bought a box of reloadable film casettes for Leicas. I had seen that they were mostly FILCAs before purchase (though one turned put to be an IXMOO with FILCA internals - which doesn't work if anyone's wondering).
What surprised me was the variation between FILCAs. There are:
- two major variants of shell design (with one major variant having some branded with Leitz and others unmarked)
- Three variants of light shield (raised Z, stamped Z and unmarked; the unmarked also has slightly different molding and machining)
- Four variants of spool (based on film holding, bottom flange and end knob engraving)
Looking at the archives here, I found this post: http://www.rangefinderforum.com/forums/showpost.php?p=749265&postcount=4
which references 4 types of Leica cassettes. In this trove I have three of these (There are three Leitz-Agfa cassettes - type D/ KASAM).
Not all FILCA parts are interchangeable, although the unmarked light shield may work on both variant outer shells. The stamped Z light traps go with the Type C cassettes while the raised Z go with the Type B. Some of the Type B cassettes seem to require the unflanged spools. I assume the unflanged type are earlier as the simplest version of film grip devices are on the unflanged spools (with the mix-and-match going on here I can't be sure one of the spools might not have initially come from a Type D).
There is also an odd light shield in the set - it looks similar to the FED style so maybe a Contax? The catch is not grooved into the light shield but notches in the end.
I see that Lager said that in thirty years he had never seen a Type C: I now have 5 in two variations.
Once I work out what is what I'll post some ads - I definitely don't need 20 film cassettes for one Leica!
I just rechecked that reference - the odd light shield seems to be from a Type A. so possibly the odd-man-out spool is as well?
I'll post some photos soon.
6 different spools (not counting the plastic one that came in one FILCA!)
DSC08060 by Scrambler@4350, on Flickr
L -> R KASAM, KASAM, FILCA B/ KASAM, FILCA B, FILCA B & C, FILCA B
The only difference between the last 2 is the milling at the top. Both of these have the small flange extension on the bottom. None of the others have this.
I think that the 4 on the right are Leica, starting with simple and becoming more complex.
You'll find a lot about old film and so on here:-
http://www.rangefinderforum.com/forums/showthread.php?t=87322&page=4
but you'll have to go through a lot of posts for the interesting pictures.
EDIT and there's this:-
http://www.rangefinderforum.com/forums/showthread.php?t=89128
A while ago I sat down and measured all the old cassettes I could find but I've lost track of the thread.
Regards, David
Thanks David. Yes, I had come across your measurement thread and respectfully disagree with your KASAM measurement which I don't think went to the tab. 🙂
I hadn't come across the FILCA variations before and the specifics of the B and C variants seemed worth throwing up in case someone else was struggling with mismatched parts.
I found the reloading inserts for the KASAM an interesting idea. Sometimes it's easy to forget that 35mm predates the Kodak 135 cassette.
Thanks, I've bookmarked it again.
I didn't measure the little lump on the Agfa cassette as I wanted consistency and was mainly wondering why the negatives came out so misplaced.
FWI, I've a lot of anonymous Leitz style cassettes and wonder about them; especially the ones with the curve mark on them.
Although I've a small collection of Leitz catalogues from the 30's I've never seen a KASAM in one and wonder more about it. To confuse the issue a lot of stuff was marked Leitz meaning it fitted or was for the Leicas but wasn't made by Leitz.
Regards, David
