Puggie
I have searched and can find the general compatability difference between the FILCA and the IXMOO cassetes. My issue is I have about half a dozen cassettes, a mix of the two. I stupidly chucked them all in a pile to load up in the dark with little (ok none whatsoever) regard to which fit which.
So i have the following:
Outer casings,
some have a base without any 'key', and some have a bump and pin as shown.
Some have an internal raised lip in the base others do not
Inner casing,
The mushroom tells all, i have 3 silver IXMOOs and 4 brass/black FILCAs, FILCAs are longer than IXMOOs incidentaly.
Spool,
All look the same, but the top knurling and undercut seem to vary as shown.
I have one odd spool, where/what is this from.
Can anyone advise which buts are compatible, I certainly assembled an over long combination, from the two as it looked like an IXMOO but didn't fit in my M4.
Pics to follow in a fairly random order
Outer casings,
Inner casing,
Spool,
