Film Counter window for S3
Range-rover
7:29 PM
Hi all.
I pick up a new window for the film counter for the S3,
whats the best type of glue to use to attach the plastic to
metal.
Thanks
Range
Epoxy will work just fine.
Be careful if you use anything with solvent, like contact cement. It may dissolve the plastic. I believe the window is plastic, not glass.
Same for cleaning the window, don't use acetone.
Ditto. Epoxy. Very small quantity applied with a toothpick so that you don't see the glue from the outside...
