tiberno
I just developed my fourth b&w film and still have some problems that I can't figure out what is causing them.
The biggest problem are some wavy stripes that can be seen in flatter, brighter areas of the pictures like in the sky. These stripes run parallel to each other during the length of the roll. Maybe that is due to unproper drying. I only hang the film there and don't use a squeegee because I don't have one.
The other problem is that the roll has a little burnt stripe in between and onto some negatives to others. Is that from a light leak on the camera?
The last problem which only happened with this last roll was a huge lost of transparency on the whole film. My printing exposure times went from 12 sec at f8 to 240 sec at f4.5!
I had an unopened old bottle of Ilfosol S which I used to develop that film and the developer was very dark, like strong tea, and the bottle also was a bit shrunk onto itself so that is probably the problem: bad developer. If that is the case why did the pictures developed at all?
Thanks for the help!
tiberno
tiberno
