oftheherd
My son-in-law has recently purchased a nice Canonet QL 17 III. It works well and he likes it. Except for loading bulk film. Commercially loaded film seems to work OK. TMAX bulk load seems OK. TX400 causes problems. About frame 6 or 7, it will no longer pull film through the camera. Sometimes by playing with it, it will work a little longer, them stop transporting the film again. I tried it with my Canonet QL 19, and the same problem occurred. He has been using plastic film cassettes.
He seems to think the TX400 is thicker, and when he used a sacrifice roll, he noted that the film seemed to curl longer, that is bigger around inside the take up area, pushing up the Canonets QL pressure plate.
Doing a search, he found this RF thread: http://www.rangefinderforum.com/forums/showthread.php?t=5764
where James Burton, also using plastic cassettes, in posts 6, 20, 22, and 25, talks about the same problem. He seemed to have problems with both a Canonet QL 17, and an EOS300. RayPA in post 8, mentions no problem, but mentions using metal cassettes.
Has anyone else had such a problem? Was there a solution other than not using that camera and film combination? Are metal cassettes better for any reason? Does James Burton's solution of waxing the end of the reels sound plausible?
Thanks for any replys that help or may help solve the problem.
