Filters for 30mm
BlackCloud
11:05 AM
Other then the provided center filter, has anyone else managed to find a filter system that won't vignette on the 30mm?
Hoya makes a thin Skylight filter, but is that the only filter I can ever use?
Well, my 67mm center filter has a 86mm front thread. I can certainly place another filter in front of the center filter without vignetting. Why not try a step-up ring and use over-size filters on your X-Pan.
PS I am using a medium-format pano camera.
I am using a LEE filter system with 58mm wide angle ring, as long as you only use one filter it's OK, stack them and you are in trouble.................
Clivel
