Filters on CV 15mm
stompyq
5:05 AM
I have a SM CV 15mm right now and want to use my filters with it. All my filters are 77mm and i would rather not buy smaller mount (specially the 10stop ND). Is their some way to mount these on the CV? I wouldn't mind buying the newer M mount version but can it take a adapter ring and 77mm filter without cutting the corners?
Also would like to hear about the SM 12mm as well (interested in getting that if i don't have to swap the SM 15mm)
I don't see how you would use an adapter ring, due to the fixed metal hood (on the M version, not sure about the screw-mount version). I don't use filters a whole ton but am in the same boat as you -- I just sprung for a B&W polarizer for the 15mm.
The hood is fixed on the older 15mm as well. Problem is the old version dosen't even have filter threads.
