Greyscale
I thought that I had loaded 400ASA, but accidently used 100, so no real test of indoor ambient light, and I also forgot to set the date function to "blank", but I'm pretty happy with the results for the most part.
Nice and wide, and sharp, sharp, sharp. I am coming to expect sharpness from Konica lenses, though.
R1-01673-0022 by Greyscale3, on Flickr
R1-01673-0017 by Greyscale3, on Flickr
R1-01673-0008 by Greyscale3, on Flickr
R1-01673-0025 by Greyscale3, on Flickr
R1-01673-0024 by Greyscale3, on Flickr
R1-01673-0003 by Greyscale3, on Flickr
Some lens flare in a couple of shots, though.
R1-01673-0019 by Greyscale3, on Flickr
muf
You left the date imprinting on? Bloody amateur!!!
Oh yeah, done that loads of times!
Nice pics btw. As you said, very sharp. Also, don't see much evidence of vignetting too. It's a zoom isn't it, so what focal length was you shooting at for these shots?
Paul
Paul
Greyscale
I had the date imprinting off, but then i went and changed the battery and it defaulted back on.
The pumpkins and the apples are the only two I zoomed on. Probably about 50mm on the pumpkins and 70mm (full zoom) on the apples. The rest were at 28mm.
btgc
I think it's really not bad as a compact wide zoom. Top mounted backlit LCD and two-directional navigation lever is probably best interface I've seen on compact camera. Note, I haven't handled posh hi-end P&S's though Lexio implements good, clear design.
