T
Todd.Hanz
Guest
Ater seeing some images posted by "Mike Richards" on Scala developed in Rodinal to produce a negative (instead of a positive slide) I decided I had to try some. there wasn't a whole lot on the web so I started with a basic "soup" recipe and times. The negatives are very sharp and tonality is great. I read that you should be able to get 8 stops max on this film, I'm not there yet. Scala is rated at EI 200, the box says you can pull this film -1 stop (EI 100) and push it +3 (EI 1600), I would opt for pulling it in mixed lighting as this is slide film and doesn't handle highlights well unless you expose for them. Here are a few samples: EI 200, "souped" in Rodinal 1:20 at 18c.
