Fixer bottle question
Rhodes
Time Lord
10:20 PM
Should one use the old fixer bottle to store the dilluted fixer for using, after a thorought whashing? Or is it unwise to do so?
I once had a bottle of fixer leak all over my floor... through age, I think.
I do not have a recommendation based on this. It was a very cheap bottle.
Chemically, used fix residue should not be too bad for fresh fixer, especially if you rinse / wash effectively.
I do not have a recommendation based on this, but if I were using glass bottles I would reuse.
Should be no problem at all. The one or two drops of non-dilute fixer still in the bottle would make no difference in the presumed bottles of 1 quart to 1 gallon.
I see! Yes, my concern is the residue of the old fixer. Do not if matters but it's ilford rapid fixer and for 35mm normally I use 300ml of solution, so it's 300ml stored in the bottle. I have old glass pharmacutical bottles but, or they do not have the right capacity or they do not have the lid.
I was not being clear, I guess. The fixer leaked out of a cheap plastic bottle. I have no idea whether the fixer ate the bottle or the bottle just decided to leak.
I would not worry about residue in the container.
What you shouldn't do is re-use bottles for different solutions (e.g. developer in a fixer bottle) - ESPECIALLY "in reverse." That is, you might get away with storing stop in a developer bottle, but I wouldn't even consider the reverse.
Besides, even though "photographic containers" are "expensive" - it's cheap enough to just buy a new one if there are ever any doubts. Personally, I prefer brown glass bottles with caps, but inevitably we all end up with those "Datatainers."
Yes, fixer in a old developer bottle should make some interesting results!;)
It's not a question of being or not expensive, more a questin of not being avaliable around here. Yes, I could order it, but if I could use one thing that is already in my home and it's sutible, I use!
Thanks for the awnsers!
I re-use one gallon heavy plastic bottles that are originally sold containing auto windshield wiper fluid for just over US$1- at discount stores. I just use up the original contents then re-use the bottle.
I have no idea what a plastic bottle of windshield wiper fluid sells for in Portugal, but I would suggest finding out.
Same for me. They're perfect, even have child-proof lids (if that's a concern).
That kind of bottles are also abundant here, did not think that they would be appropriated for developing chemicals. If so, I'll use!
I use washer fluid bottles as well. I usually use the contents,wash them out and fill them with fixer or developer. Mark them accordingly and reuse them as needed.
