Fixing Nikkor Zoom Creep.
Rob-F
Likes Leicas
6:52 PM
I have an 80-200mm f/4.5 with the usual zoom creep. I'm thinking of trying a DIY to fix the zoom creep. I have very little money in it, so I won't be upset if I mess it up. I've got good screwdrivers and a spanner. But I never took a zoom lens apart before. How can I get some info and suggestions for doing this?
Not sure if applicable to the creep problem on a one touch zoom, but
I had an old 105/2.5 Nikkor lens that had a very worn focusing helical.
A coworker replaced the grease with a stiffer type, which helped a bit.
Chris
I have an 80-200mm f/4.5 with the usual zoom creep. I'm thinking of trying a DIY to fix the zoom creep. ...
You can't "fix" something that isn't broken. The "creep" is as designed, and Nikon's "fix" is for you to keep your hand on the zoom/focus grip while shooting. These lenses had very light operation when new out-of-the-box.
The zoom action on one-touch Nikkor zooms of that era is intended to be light and smooth to allow fast easy change in hand-held operation. You'll find it a rather difficult task to modify the lens to increase the drag while maintaining any degree of smooth operation.
No, zoom creep is not a design feature. Zooming should be smooth but there should be some resistance.
Typically a lens is said to exhibit zoom creep when it changes focal length when stood on end.
A workaround is to keep your hand on the collar at all times, but that shouldn't be required.
Chris
