Focomat Ic: mounting AN-glass "NESOO" correctly
Ljós
5:18 PM
Germany
Hello all,
I have gladly and proudly taken possession of a very nice Focomat Ic, and I am happy as can be. NICE! The negative-handling is just superb, I can position negatives (even those at the end of a strip, which can be a PAIN with other enlargers) swiftly and precisely... and of course the autofocus is a boon.
(Even better: this Focomat Ic has been expertly tricked out with a colour-head (Dunco, via a Kienzle-adapter)... I can even switch the colour module for a VC-module further down the road, then I could set paper grades without adjusting exposure. The colour head has a stepless density mask which is good for up to two stops though, very convenient. The mechanical qualities of the Focomat plus the modern colour head, it is heaven 🙂)
So, the first prints were phantastic, and without Newton rings... during later sessions, yep, Newton rings showed, and I sourced a NESOO anti-Newton glass with mount plus the corresponding distance ring. Here is my question:
On arrival I think the glass itself was mounted upside down, but I am not 100 percent sure. It would be great if you could help me out, since I cannot find a detailed description or manual anywhere:
Let's forget about the spacer ring for a moment, it is clear where it goes and what it does. So, the NESOO itself is comprised of three parts: the glass disk, the part that slips on the condensor, and a threaded ring which sandwiches the glass. The glass is angled at the rim, and my question is: do I fit the glass in such a way that, when all is mounted, the AN-glass protrudes a tiny bit? (That is what I think. Makes the most sense. But it arrived at my doorstep the other way round, with the smaller surface diameter upwards.)
Thanks in advance for your help!
Greetings, Ljós
Thomas, thank you very much!
Don't wanna go to the trouble of finding AN-glass and then mucking up the mounting 🙂
What I like about the three-part-construction: before I realized the sandwiching-ring can be screwed off I thought: gee, that's going to be tough to "slip" on so that the glass fith without air-space and parallel, since the "slip-on"-ring fit quite tightly.
But this way, one can mount the slip-on ring without fear of harming anything, clean the surfaces, and fasten the glass disk with the outer ring.
Did I mention I am in love with the Ic? Such a wonderful tool.
Greetings, Ljós
Update regarding the slip-on ring: I had "practiced" with an older Focomat (hard to tell the model, Ia? Ib?). Mounting on the Ic it turns out: the condenser of the old model is noticeably shorter, the are not interchangeable as is. And: the slip-on ring really does just slip on the Ic, perfect fit.
Greetings, Ljós
