tho60
I believed that Rodinal and its clones were eternal. Now I developed a roll in Fomadon R 09 (expired in 2016 November) and I got almost blank frames. The film leader is not black, but grey. What is your opinion?
sepiareverb
genius and moron
Sounds like it wasn't developed enough.
FalseDigital
BKK -> Tokyo
I also used some older Fomadon R09 and got nothing but blanks. I'm positive my dev times were correct so I'm pretty convinced it's not the same as Rodinal.
Larry H-L
In my experience it lasts fairly long, if undiluted. Once diluted, a very short shelf life.
ChrisPlatt
Thread Killer
I have read more than a few reports of similar problems with R09.
If stored and used properly this is disconcerting and disappointing.
Rodinal users expect this developer to be reliable with long shelf-life.
My next bottle of Rodinal-clone developer will be another brand.
Chris
Chris
Ong
At the end of the day, it doesn't seem to be a problem just limited to R09.
I had the same issue of Adox Adonal and R09. Both undiluted and used as a one shot when required.
So YMMV, all I know is that I'm moving to Fuji SPD as a oneshot instead and no more R09/Rodinal/Adonal/Clones for me.
FalseDigital
BKK -> Tokyo
Speaking of Fujifilm SPD, I don't see much info about it online in English.
If you don't mind me asking, what films are you developing with it and what are your dev times? Any samples?
FalseDigital
BKK -> Tokyo
I mixed a fresh batch from undiluted stock and got blanks. So I really don't trust the stuff anymore. Pretty much only use HC-110 now (if I can get it) because that stuff seems to survive the heat in Thailand quite well.
ChrisPlatt
Thread Killer
A true Rodinal clone - made using the original AGFA formula, as most brands claim - should have extended shelf life in concentrate form.
IMO this is an essential characteristic of anything calling itself Rodinal, and a major reason many darkroom workers choose this developer.
Chris
Chris
Bill Clark
Larry H-L
Those of us in cooler climates seem to be getting longer R09 shelf life, perhaps it is heat related.
Kodak HC-110 seems to last for decades in heavy syrup form if tightly capped, but I have heard that the non-US version is less concentrated?
Freakscene
Obscure member
This has more to do with the packaging than the developer. No chemical lasts very long, let alone 'almost indefinitely' in packaging that readily allows diffusion of oxygen.
Marty
Marty
FalseDigital
BKK -> Tokyo
It is most likely heat related. I live in Thailand and it's always hot with high humidity here. Most chemicals don't last long.
michaelwj
I'm in Brisbane, hot and humid. I keep my R09 in the fridge next to my other chemicals and they last well enough that I haven't had any issues.
My film goes on a higher shelf.
nhchen
Nathan
Ah maybe that’s what I should do also. I’ve had two bottles of the R09 go off in the last few years.
Nathan
Freakscene
Obscure member
You could also try buying some glass bottles that seal properly to put it in, like:
https://www.sigmaaldrich.com/catalog/product/aldrich/z305197?lang=en®ion=AU
Marty
Marty
