Calzone
Gear Whore #1
- Local time
- 10:36 PM
- Joined
- Nov 11, 2008
- Messages
- 16,953
- Location
- The Gateway To The Hudson Highlands
Hello,
I'm a film guy who is way out of his element, but earlier today a friend gave me this CCTV lens that I assume is a C-mount. It is a Cosmicar/Pentax 8-48mm zoom lens with a F-22 to F1.0 range.
It also has a E55 B&W filter on it that says "NL 3", but also a yellow filter without a ring sandwiched in between the B&W filter and the front element. BTW the B&W NL 3 is not flat and displays a convex front.
Any help in educating me as far as equiv. FOV range in 35mm?
Also Although 1:1.0 is clearly marked on the lens barrel the there are two signified F-stops for wide open: 1.0<W; and 1.2<T. Any idea what this means?
Last question is on a Nex-7 at what focal length does vignetting become evident with CCTV lenses with C-mount?
Thanks in advance.
I'm hoping I effectively found a Noctilux zoom that will work well on a Nex-7
Cal
Thanks in advance.
Cal
