Fuji x100 in 2017?
Landberg
11:14 AM
Hi!
I have found a brand new black edition X100 (the first) for a very cheap price. I used to own the first x100 back in 2011 but i have lost all my original files. I have one jpg left but it is a small one. How is this camera holding up? Did the focus speed firmware do any difference? Any thoughts? Is anyone still using it?
I still use mine, although not as my only camera. The image quality (for me) is very good. I have printed 8x10 and they look great. The focusing is not speedy, but it's fine for what I do and haven't found it to be a problem. I like the OVF. It's really really quiet.
I just bought an original X100 to go with my M.
I figured it was cheaper than buying a good 35mm lens for FF (having sold my Nokton 35) plus I could comfortably carry bough cameras rather than switching lenses for when I wanted.
The files from it I found to be pretty decent. There is a nice look to them thanks to the standard Bayer sensor. AF isn't amazing but I wouldn't say it was atrocious. Depends on your uses. For me it's more than enough. You can pick them up quite cheap if you look around. Look for a later serial if you can as some of the early ones had sticky aperture blades.
My experience as well. It's a very pleasant camera to shoot with, just the right size, easy to bring along as a second (or third) camera, and I'm always happy with the results. I mostly shoot things that don't move; focusing speed is fine for me.
Lots of us still happy with it. Mine was an early one and eventually replaced for a too loose exposure compensation dial, and a dodgy shutter speed dial that got stuck on 1/4000s and wouldn't go to A. The later ones are better, especially the T, but not enough for me to change up.
I'm in the same boat. Wondering if it's a good option buying a X100 right now. Here in Italy prices of the other models - even used - are far too high.
I already own a X-T1 and X-T20 so maybe the original X100 could be a good complement.
The original X100 I used was a pain. It just can't...focus. You have to continuously wrest with it.
People would say it produces decent files, but which camera doesn't? Be nice to yourself and get something newer. Technology does advance and that really makes a difference, as I have experienced with the X100T and F.
I picked one up a few months ago very cheap. With the latest firmware it is fairly responsive but I wouldn't call it fast. Image quality is quite good. The onboard flash works surprisingly well and it has a flash commander mode. I use it but it's not my main camera. Worth the cheap price I think.
Even with the firmware upgrades?
The AF (set up for back-button focus) on my original x100 with the latest firmware, is just fine for my purposes.
I wouldn't try to shoot fast-moving sports with it, but I doubt that many people would want to use this type of camera for sports... ;)
Can you explain how to set it for back-button focus?
Set the camera to Manual Focus. Then go into the menus, and set the AE/AF-LOCK button (a.k.a. 'back' button) to AF LOCK ONLY. Then you can use the AE/AF-LOCK button for 'focus and re-compose' shooting.
Of course, this has no bearing on the AF speed - it just happens to be how I like to use the camera. :)
Hi!
I would not hesitate to buy that camera if I were in your shoes :)
Go through the firmware updates and enjoy the camera, black cameras are my favorites.
The original X100 is the only model that appeals to me.
And like you it's also the only version I can afford, as well... :rolleyes:
Chris
TBH I was undecided between this and X-Pro1 but just now I'll go with this one, maybe later, much later, I'll get a X-PRO1. Who knows?
Yes, I still use my black x100 purchased 2012. I have other (newer) cameras but the x100 comes to the party while the others stay on the shelf.
Take care,
Lou
Just because they're older doesn't mean they can't make great photos. All my current cameras were bought used, open-box or as closeout models.
While I know the sensors are different and some people prefer the look of the Bayer over the Xtrans, you might look for an X100S in good used condition as an alternative. The "S" offered some significant improvements on the original model--particularly the AF--and it might be found at a price that's only a little more than the original X100. In my opinion, the added features and improvements of the later models have not been significant enough to warrant a switch from the "S".
I like the X100S enough to have two of them--one to use as is with the built-in 23mm lens and one to use with the conversion lenses.
