Interesting comment, thank you.
My Fulvia Coupé is a 1967 model, sold new a year or three before the US Federal bumper height regulations were put into place. Never mind that, like most Fulvia Coupés I've seen at the annual Lancia Club meetings, the bumpers on mine have been removed (as per the standard Rally production HF models) and so the question of bumper height has been rendered moot ... Otherwise, the rear ride height is standard on this one and the front ride height has been lowered 20mm (and the front suspension arm lengths juggled a little bit) to achieve better overall suspension geometry and give it a touch of 'rake' from front to back.
However, the Fulvia Coupé always gives the impression of riding a bit high because it is a very small, light car and needs a good bit of suspension room to give a good ride along with its good compliance and handling. My car also seems to be riding a bit higher in this photo because of the body paint treatment ... I had the lower body panels, below the door sill, painted black when I did some rust repair a year or so back. To my eye, it thin⁷s out the body line a trifle and looks more sporty than the standard body color all the way down the to bottom edge with a chrome trim strip. You can see the difference more clearly with these two photos:
(Note also the change from the Campagnolo 13x5.5" wheels with 185/70-R13 tires in the upper photo to the Chromodora 14x6" wheels with 175/70-R14 tires in the lower photo... This also changes the appearance of its ride height as the larger wheels and shorter sidewalls tend to dominate the side-view proportions. It also restores the original gearing ... I got tired of having to spin the engine up to 4300 rpm to maintain a continuous 70ish mph highway speed when traveling; it now revs 3900 rpm at 70ish mph, much more relaxed for any distance use.)
The Fanalone style headlamp setup is being installed now, which will change the car's look yet a little further ... the 8" center high-low headlamps add a little more aggression to the front end and also make it look a little lower up front (never mind provide a LOT more light on the road in both low and high beam settings!) since the tops of the headlamps do not change, but the bottoms drop down another 1.25"...
The featured B&W photo in this thread is a bit high on contrast and the lower body line disappears into the shadows, which makes the car seem to ride a little higher than it actually does. It's quite low yet still has a goodly amount of ground clearance to match its World Rally Cup heritage...
Gads, I'm nutty on this car.
G
