Gang Lab Paper Holding Tank
rlouzan
3:58 PM
Legal Disclaimer: The author of this post disclaims all liability for any damages resulting from the use of the following information. Intended for general educational purposes only! :eek:
FB & RC Paper Holding Tank :D
Approx. Dimensions: 35 x 50 x 40 cm (14 x 20 x 16")
Necessary Parts:
1) 1 - Stainless Steel Box Approx. Dimensions: 35 x 55 x 40 cm
(from Restaurant Supply Store, Junkyard, costume made ...)
2) 1 - Outdoor Faucet.
3) 1 - Water Garden Hose.
4) 1- Water Hose Quick Coupling (pvc, Brass, ... )
You'll also need the assistance of a machinist, but the work there is minimal (two holes and a sliding door).
Total cost, less than $100
TEST
1) Open Faucet.
2) Fill Holding Tank 2/3.
3) Close Faucet.
4) Pour food coloring, from Pharmacy, in water.
5) Stir powder in water.
6) Open Faucet.
7) Open partially sliding door.
8) Food coloring should be gone in 10 - 15 min.
9) If not, adjust water flow and repeat Steps 1-8.
As an alternate to the sliding door outlet, you could use a second, smaller tap to regulate the out-flow.
The slit is located Approx. 1,5 cm (1/2") from the bottom. The reason behind the sliding door is that it is easier to dump the remaining water, in the holding tank, after a printing session :).
Regards,
RLouzan
thanx for this rlouzan, prints standing vertical in carriers way to go with this ? or are they put in flat and loose, cheers
Flat and loose:D Please remember that it is only a holding tank and not a Archival print washer.
Stay Tuned for:
Archival FB print washer (Next Week)
Best,
RLouzan
