Frankd
I am renting a Lumix GH5 in a few weeks but may reconsider if my software, Capture One v8.4 cannot read them.
I wonder is someone can help me to determine if my software will read GH5 raw files. Can someone email me a raw file? I know they are rather large but it would help out a lot and make a final determination.
PaulDalex
Dilettante artist
Hi Frank
I use it for video.
I could make a photo for you, but I am afraid that I will get a file too large error from my horrible Italian provider.
On the other hand I have Capture 10 and you made me curious to try.
The camera itself can process RAW to generate a JPEG (I guess the same JPEG that you obtain setting the camera to JPEG+RAW)
The manual recommends the software SILKYPIX to develop a RAW
BTW how can I get your email address?
Cheers
Paolo
I use it for video.
Cheers
Paolo
PaulDalex
Dilettante artist
I checked Silkypix and it is quite expensive!
tbhv55
I don't know whether there's any specific data in the GH5's Raw files that is only available directly from those (.RW2) files, but if not, then why not download Adobe DNG converter? The GH5 is supported, and AFAIK, capture1 will open DNG files. It's also free!
Might be worth a look.
Darthfeeble
But you can call me Steve
I couldn't open the Raw files from my XE3 until I converted them to DNG. I have C1, ver10
Frankd
Thank you Tbhv55, Pistach, and Darthfeeble.
The DNG converter was a good idea. However, my real problem is that I have an older Mac OS. Otherwise I could get the latest version of Capture One and that would probably work for GH5 files. Adobe DNG converter won't work for the same reason. Probably a raw file would need to be sent via Dropbox or Google Drive.
Darthfeeble
I lied about the Fuji files. Actually I was premature, they showed on the program until it created previews and then the files were corrupted.
Frankd
Yes, Darthfeeble, it can be frustrating. Sometimes things appear to be working. I have found at times with C1 it will display a file but won't allow you to do any modifications to it. It does not work on Greyscale files. Maybe the next C1 upgrade will handle the XE3 files. I can't believe that they won't since this is a popular camera. All part of the software/hardware run around!
Darthfeeble
I tried the trial of version 11 and it seems to work fine but I'm not paying again just to update a camera. They won't update the version I have and Lightroom seems to have the RAF files under control so phoey on C1.
tbhv55
Another thought: you could download Rawtherapee (free), use it simply as a raw converter (to produce a TIF file), and then edit as usual in capture1.
PaulDalex
Dilettante artist
Hi Frank,
I verified that C1 10 opens the raw file.
The file is 23,6 megabytes. I think it is not possible to send it by mail
I also verified that Raw Therapy can open the file
PaulDalex
Dilettante artist
Frank,
I replied to your message from within RFF
I am not sure my reply arrived to you, since I am not being using this communication channel for a long while.
Let me know by a post if it arrived to you.
Frankd
Thanks tbhv55. Looks like Rawtherapee might work. It seems to take GH4 raw files. I just need to figure out how it all works! It is very different from Photoshop or Capture 1.
PaulDalex
Dilettante artist
My gut feeling is that C1 does a way better job than Rawtherapy.
tbhv55
The OP stated that his version of capture1 won't open the Raw files from the GH5 - that's the reason for this thread!
tbhv55
I wouldn't get too mixed up in using Rawtherapee for processing (unless, of course, you want to
If you prefer to keep it simple, Rawtherapee can convert the Raw files straight to TIF without doing any processing at all - leaving you to do the editing in capture1, as you would normally do.
PaulDalex
Dilettante artist
Hi tbhv55
C1 10 does.
And Frank asked me to check.
I looked at the test photo opened by Rawt and C1 10 and I liked better the second.
I can be mistaken of course
C1 10 does.
