Leica LTM Got my 15mm Voigtlander lens today
colyn
ישו משיח
11:25 PM
I also bought the 50/75mm adapter so I can use this lens on my M cameras. Looking through the clip-on viewfinder gives an interesting field of view. This should be a fun lens to use.
One thing I did notice is that I won't be able to use this lens with the accy hand grip since my fingers will protrude into the field of view..
Congrat's Colyn! It's a great lens... The finder does distort things a little, but I've found very little of that with the resulting photo's. Be careful to frame pretty loosely because you will often get more into your shots than expected.
Have fun & share some shots when you have them.
Peter
Peter
Will do...
Hi Colyn, Congrats - fun is definitely what it is ;)
And you definitely do need to be careful of your fingers. Even without an accy grip I've managed to get fingers in the way a couple of times, at the bottom of the frame (where you can't see them in the viewfinder)
