Has anyone tried Sugru?
madNbad
3:28 AM
Portland, Oregon
In my never ending search to find a buffering material to keep metal eyepieces from scratching my glasses, the latest is Sugru. It's a mouldable glue that dries to the consistency of silicone. I've just coated the eyepiece on my Retina IIc and now have to wait 24 hours to see if it was successful.
I've tried it too but it rubs off in my jacket pocket. If the Sugru doesn't work just by it self, the next step is to try it as an adhesive to hold an O ring in place.
Sugru is great! I've fashioned it on the back of Fuji cameras as a grip of sorts, also to prevent accidental button presses...should work great on your Retina. Keep us posted...
I have used it on viewfinders and to fill in some missing vulcanite. It's good to have around and easy to work with. Seems to leave a residue on metal with a sheen though, it finds its way into rough surfaces.
Amazing stuff. I have used it much in the same way, to build up the grip on cameras so I have a better hold. Also used it for many other applications. It has unique qualities. It remains flexible but it also sticks. Handles like clay or putty. Easy to shape / form. Only downside is the cost. Keep unused packs in the fridge - it lasts longer that way.
Greyhoundman, a former forum member always recommended adhesive Velcro cut to shape, you can even buy it as dots which are about viewfinder size. Works very well, I have used it on Leica and Canon viewfinders.
Not the neatest job and I'll still use my cheap glasses but here it is;
[/url]IMG_1822 by Michael DeLuca, on Flickr[/IMG]
Thanks for showing your result. I've tried most of the DIY ideas from this thread, except Sugru, and haven't been very successful with any of them. I think I'll pick up a pack and give it a try.
Something that has occurred to me as a possibility is to take some felt or rubber material of 2-3 millimetres thick. The sort which is used to make the little stick-on furniture protectors (typically placed on the bottom of objects d'art to protect furniture from being scratched) would be possible sources.
Then if you can find some appropriately sized hole punches (available in hardware and craft stores, often in sets) you could punch a smaller hole equivalent to the size of he rear finder lens and concentric with, it a larger hole to create the final "donut". This would give you a soft protector which could be glued onto the the metal surround of the finder - perhaps with silicone which holds quite securely but can be removed if needed. This arrangement would allow new protectors to be installed when ever they need replacing or if the old one is lost.
I have all of the above and should try it but have not bothered as I typically shoot without my eyeglasses and using a screw in diopter to correct for my eyesight.
I've used Sugru for electrical repairs, but I feel it doesn't turn out as “rubbery” as the advertising implies... for me the finished texture is more like stiff, only slightly flexible plastic. Not sure it would be my first choice for an eyepiece protector. Other than the purpose-made stick-on circles, my best luck has been with rubber hose washers.
Leica parts no longer sells the rubber coated eyepiece used on the M6, M7 and MP, fortunately, Don Goldberg has a snap on plastic cover. They work well, stay on and don't cost a lot. Recently, there is a seller on E-bay with a similar product for the M cameras. I'm trying one now to compare to the DAG cover. The problem is with a camera like the Retina where there isn't a ready made product. I've tried the stick on felt but inevitably they fall off at the most inappropriate time. Rubber O rings are a great idea but finding an adhesive that will both keep the ring in place and not out gas into the finder is a problem. I looked at silicone caulk, leather washers, nylon washers and any number of other gimcracks. The attraction to the Retina is it fits in a jacket pocket. Most of the stick on eyepiece covers is they come off in the pocket. Hopefully, this will stay on. Thanks for all of the suggestions.
