Hasselblad Xpan help
njrfotografia
2:47 AM
Hi all
Does any one here have a pdf file or can anyone direct me to where I can find a hasselblad Xpan 30mm f5.6 manual please? Quite an urgent and desperate plea!
Also, when using the Xpan 30mm viewfinder, which lines inside the viewfinder are the correct lines to follow when framing a panoramic with the 30mm?
Cheers
What's your questions? PM me if you want.
The large solid frame is the one you want. The corner slight to the right is for parallax. The middle block is for when using the non-pano mode.
