HC-110 or Rodinal for contrast?
  • Total voters
    5
erikhaugsby
killer of threads
3:54 PM
I don't want to start a flame war, but...
My local camera shop has 4 500mL bottles of Agfa Rodinal left for a parsly $9.89 apice, and they have plenty of HC-110 stocked at $12.99 a bottle (concentrate apparently makes 2 gallons, didn't bother to see what dillution they use.)
My question to you: What developer would you prefer if you are interested in contrast more than anything else (fine grain, resolution...)? I am leaning towards the HC-110 purely because I know that it isn't discontinued at the moment, but I have little other information to base a decision on.
For the record, I usually use FP4 @125 and Tri-X at ISO400, sometimes 800
Thanks,
Erik
Are you looking for high contrast? dev for longer in either...
I find Rodinal kills shadow detail, I rate FP4 at 64 in Rodinal 1:50, and would probably go EI 50 or lower if I used 1:25. I likr the look though.
Also, Rodinal is being maunfactured again, I suspect this is what you have seen. Though I can't remember the differences in the new labels...
I use both developers for both films and I think that there is indeed a difference.
For me Tri-X at 1:50 in Rodinal isn't contrasty enough. It seems to really bring out the mid-tones think of Selgado's work with the really rich grey mid-tones. If I'm scanning I can always adjust this but I find that I like the negatives better in HC-110 for this reason.
Using Rodinal at 1:25 for Tri-X makes it more contrasty but also more grainy. For really high contrast like the kind seen in Ralph Gibson's work, Tri-X in Rodinal developed for 11 minutes rather than the usual 7 will give you very dense, very contrasty and very grainy negatives. It works for him. I find that it's not suited for general photography but can work on the right subjects.
Since the revamp of Tri-X where they changed the recommended times of HC-110 Dilution B (1:31) to under 5 minutes, I've been using HC-110 at 1:50 (from concentrate, I never make a stock soluiton as the directions say to). I end up with contrasty but not overly contrasty negatives that both scan and print well. I recently switched back to this after a Rodinal phase.
Conversly, with FP4, I find that HC-110 makes it look overly contrasty with no midtones. So I use Rodinal at 1:50 for FP4 and get much nicer, more balanced tones.
Take it for what it's worth. It might due to my own idiosyncracies but I've spent a lot of time with both film and both developers trying to find what works for me. Your milage may vary.
In general I agree with nightfly. IMO the primary strength of Rodinal is in its compensating action and high acutance at higher dilutions. At 1:25 it is more muscular, but acutance is not nearly as good, so there is more apparent grain. HC-110 also give good acutance and microcontrast, but can be more muscular without giving the appearance of grain at lower dilutions. Hope this makes sense. I haven't made direct controlled tests for a long time, so my opinion is worth what you're paying for it.
All that said, I love Rodinal.
I'm using HC110 a lot now, and I've found that it gives extremely dark shadows with Neopan 400 especially and also TriX. Very black blacks, very contrasty. I use it mostly with HP5, which tames the contrast somewhat, and seems to be a great combination to me.
I like and use Rodinal too, but these days I just save it for PanFPlus.
That means that you develop too long and probably rate your film at a too high ISO.
I'm talking about Neopan 400 @ 400. No pushing. In fact I simply steer clear of that film now. Hp5 gives me everything I need and more.
You could be right though. I didn't try reducing development time.
