Helios-103 Coating
Krawczyk
Alberto Krawczyk
3:41 AM
Brazil
Looking my H-103 it seems to haven't coating. All pictures of this lens in Internet seems not have coating too. You lens is like my lens?
Yep, mine is like that as well.
The lens is (IIRC)coated, but yep, if it's true, it's one of the most transparent coatings I've seen 🙂
They are coated, but the reflected light looks "white". But the intensity is far less than a "real" uncoated lens. Made me wonder too, until i hold it next to the uncoated Elmar.
You would not see the diaphragm so clearly in an uncoated lens. For example, both taking and viewing lenses on this prewar Rolleiflex Automat are uncoated (spotless and clear).
Yes, my 103 is very clear, I asked about it here in the same way, apparently it's not a problem:. I posted a pic with J8 for comparison.
http://www.rangefinderforum.com/forums/showthread.php?t=15587
I see that yours is also a 1984 model, I guess that you bought yours as "new". Have you also noticed that the aperture blades are not dark, but bare metal finish.
I must say that I am pleased with mine so far, not sure if problems with flare will descend upon me later.. enjoy.
The flare of H-103 is typically not distinct aperture-shaped polygons, but rather overexposure/washout spot in the center part of image.
