Help choosing Contax SLR
littleearth
8:37 PM
A Contax Planar 50mm f1.4 sort of landed in my hands recently and I need a body for it.
I've had a 139Q in the past and I've handled a few others, so I more or less know the bodies.
A friend of mine has a Contax 167MT and an RX that he is willing to sell, so those are my choices at the moment (no budget for the Aria or S2).
They are both in great condition and have a good price, but the RX does cost twice as much.
Is the RX worth it or should I save some money and go with the 167MT ?
I had the 167MT some years ago, it was OK enough but it felt a bit old and sluggish, mainly due to the user interface. I replaced it with an RX and what a fun camera to shoot. The user interface is just right and I love the un-coupled autofocus which is a very good help in dim light. It has also got the programmable button on the front which I use as auto exposure lock. If you can afford the RX I say go for it!
If considering those two, I would also look at an ST, which I preferred over my RXs due to the brighter viewfinder. The "focus aid" thing on the RX, I always found to be really slow, and more of a marketing gimmick than something which made the camera more real world useful than just quickly using one of the nice screens to focus. There is a real lag to the "focus aid". It takes time to catch up to every focus adjustment you make. That being said, I was very happy with the RXs I owned until I got an ST.
Personal opinion only, not intending to tell you what to do.
I found ST and RX quite nice, but I then again I liked all Contax SLRs that I have owned. :)
I prefer the smaller/lighter models like the 139 and the 159, the latter has 1/4000.
The defining feature of the 167MT is the slider switch for shutter speeds rather than a dedicated dial. If you can live with that, and don't need the additional features of the RX, go with the cheaper one.
Both are using the same glass and metering system, so the results are going to be identical.
Out of the two I‘d choose the 167MT. Smaller, normal batteries and imo better build quality. But changing shutter speeds is quirky so its best to shoot in AV mode. For the rest I‘d get an RTS as perfect back up body.
A friend of mine has the ST, indeed a fine camera with faster shutter speeds and 1/200 flash sync, but unfortunately no multiple exposure setting or MLU. Also AEL only works with spot metering unlike the RX, so overall the newer RX sounds like a better deal.
I did notice that most of these cameras went up in price, except for the 167MT which is more common, since it had a long run and has the less appealing 80's interface.
I understand that, all depends on what you value the most.
The brighter viewfinder and easier focusing was more important to me, because it effects every single frame you shoot. I grew up scarred by accidental multiple exposures on Brownies ruining my day, and not really drawn to doing them on purpose, and the MLU is nice to have, though rarely for me, and not worth losing the brighter viewfinder. To me.
For someone else, those things might be worth more than the focusing ease and precision. It's not that the RX finder is dim, it isn't, I just found it easier and faster to focus the ST.
But, the AEL, MLU, and multiple exposure of the RX are all good points and worth noting.
There's always the Yashica FR1 which is pretty much an RTS with different branding.
Both are very nice cameras. And, inexpensive way to use your new lens.
They are all a pleasure to use and worth buying !
I do like to shoot landscapes, so MLU and having a center-mounted tripod socket are welcome features.
The RX II has everything the RX had apart from focus confirmation. Losing the focus confirmation made the viewfinder brighter, like the ST. But the ST has illuminated controls, ceramic backing plate and a quieter motor. They both handle really well.
I think any Contax SLR apart from the S2 is an awesome buy, with the caveat that if they break they might be unfixable. There is an ST on eBay now from Japan in decent condition for $US109.60. That’s an amazing deal, and the ST balances really well with the 50/1.4.
Marty
I had a 139Q with the 50mm f/1.4. I really loved it. I got a motor wind for it and hated it. The first few times I felt kind of important. After that, the added weight and noise made me take it off. So, move on the the chance to get a 167mt and I jumped for it. I was OK with everything but the motor wind. But I got used to it.
I normally shoot it in AP mode so the objections about changing shutter speeds didn't bother me. The 4000 always impressed me, just like it did on the Fujica ST 801 which I used to want (and finally got). But honestly, I have never had a reason to use those speeds on either camera.
FWIW, I got a Yashica FX3 as a backup for the 139Q. I've never had to use it except when the 139Q conked out after a house fire. The latter Yashica's used the C/Y mount.
I would just suggest you look at how and what you like to photograph, and what you like your current cameras to do. Get a replacement that does all that, not what you think you might like, unless you are certain you will need it.
There was another thread recently on Contax cameras to acquire. A forum search may show others.
Will your friend let you run a roll of film through both before you decide?
If so, do that and then you'll likely have your answer.
Rob
I just bought a Contax ST with the 50/1.4 AEJ Planar as I got a very, very good deal on it. After reducing my gear down to a M6 with two lenses - the ZM C Sonnar and the CV 35/2.5 - I was looking for an electronic SLR as an alternative when I felt like quick AE shooting and much closer focusing distance since 90cm does not always cut it with the Sonnar for close up portraits. The Zeiss glass got me over the line since I have fallen in love with how Zeiss renders on film. I looked at the RX and RTS III specs carefully but decided on the ST since it seems like the viewfinder display is simpler and more to my taste. However, wondering about one thing before the package arrives: is anyone able to tell me what colour the LEDs are in the ST? Green or red? Or even blue? I could not find any info or pictures online.
ST leds are red.
Awesome. Thank you. My preference! Do you also happen to know if it is worth investing in the battery vertical grip? I am not expecting long battery life but I noticed that the 4 x AAAs only have an approximate life of 33 rolls of 36 exp., not exactly a lot when travelling ... though no travelling on the cards during COVID days!
I like how the ST handles with the grip, and it really works well for portrait orientation. The ST uses 4xAAA batteries whether you use the grip or not, so the battery life is the same.
You could get 2 sets of nice AAA rechargeable batteries and travel with a charger.
Marty
Marty
Thanks Marty. Yep, if the ST gels with me, as I suspect it will, I will def get some rechargeables. But my understanding is that the vertical grip houses 4 more batteries which contribute to the power source of the camera. Is that not the case? Are those batteries powering the grip only?
The grip takes up the battery space in the camera, so the 4 batteries in the camera cannot be fitted when the grip is used.
Marty
