HELP: M8 & Metz 32MZ 3 w/ SCA 3502 M4
robklurfield
eclipse
4:45 AM
Does any have experience with this combination? I need some help setting the Mecablitz correctly. I can't seem to get a proper exposure with the unit set to TTL mode? Can you share the settings you use? Thanks!
You never will get it to work in TTL, it is not equipped for M-TTL, which the M8 uses. You can only use it on one of the "A" modes or "M" It is a wise choice. This is one of the best flash units there is for the M8/9. Disable the functions in the SCA adapter as well.
Jaap, thanks. What about the GN setting on the SCA... off, I presume. I think it was a good deal. The SCA looks unused and the MZ is a little beat up cosmetically. The whole thing was about $80 US. Any other suggestions about settings? Again, thanks.
