help me decide on gear
atelier7
2:45 AM
Need help on where $ can be best spent.
I've got a Bessa R and Color skopar 35, Olympus e500 with twin lens covering 23 to 300mm and a Canon A610 compact digicam. Which of the following would be the best addition that would lend the most use?
1. GR2 (compact camera that i can keep with me all the time, as opposed to 3 cameras that usually sit on the shelf)
2. Nokton 50 1.5 (to cover low light situations, but i don't use the bessa that much - developing film is becoming quite expensive in Sydney. but i do enjoy the creative exercise when i do take it out.)
3. olympus Pancake 28 f2.8 (to make the oly more compact and the single focal lens more rf-ish)
4. Olympus Flash (i've never used a separate flash, but properly adjusted/ bounced off etc... seems to produce reasonably good effects)
5. Fast film and developing?
6. Your suggestion?
Personally, I think an additional campact camera can add a lot of fun and give you loads of opportunities which your current 2 options may not present.
