Leica LTM Help me focus my project - lens & finder for a If RD?
  • 35mm f/3.5 Summaron with C-V 28-35 Minifinder
    Votes: 0 0.0%
  • 50mm f/3.5 Elmar with C-V 50mm finder
    Votes: 0 0.0%
  • Other
    Votes: 0 0.0%
  • Total voters
    15
  • Poll closed .
Ken Ford
Refuses to suffer fools
4:59 AM
Some of you may have seen my thread from the other day where I treated myself to a clean If red dial:
attachment.php
attachment.php
I'm having fun deciding what I want to put on this body. It will hopefully be used as a semi-regular carry camera for my walks in town.
Not having a RF I feel it is best suited for a wide, but I'm also considering an Elmar 50. My original intent was to use a C-V click-focus 25/4 but the finder for these isn't the most durable. I thought about an ultra-wide, but I'd like something more versatile. A 24mm was my preferred walkaround lens for many years on a Nikon.
Any arguments for the choices presented? I'm not promising to follow the pack choice, but I'd love to hear what arguments are presented for various lens/finder combinations.
Thanks!
try it with a 50mm Elmar or its FSU clones, and a SBOOI finder.
guess focusing a 50mm lens on a sunny day is very easy and accurate.
Use the 25/4 lens anyway and use a different finder. You can make your own compact finder from a shoe (from a dead flash) and a door peephole. It won't be rectilinearly corrected, but with a little practice and/or a cutout mask it works surprisingly well. A friend uses one for his 21, and the peephole "finder" is very small, all-metal and quite durable :)
Or use a Helios finder (cheap, reasonably compact and durable) and a Jupiter-12 (excellent low-cost wideangle). You can get an excellent 35mm solution for under $50. The high-cost variant of this would be the Cosina 28/35 minifinder.
Philipp
The 28 Color Skopar with mini finder is a killer lens on any Barnack.
And on your camera, you have room for both finder and CV meter.
Roland.
In a recent thread, opinion was fairly evenly divided between 35 mm and 50 mm. In the absence of a range-finder, 35 mm wins. The SBLOO is an excellent finder, if you can get hold of one.
I'm starting to lean to keeping this a period piece with either a 5cm Elmar and SBOOI or a 3.5cm Summaron and SBLOO...
Yep, that`s the best thing to do........F3.5 50mm Elmar and SBOOI was the standard equipment plus a chrome FOKOS rangefinder (I think that`s what they called them?)
The IF RD is more a collectors item then shooter, I know they were crazy about these back in the 1990`s back in Europe, all the collectors wanted one, they are hard to find in good condition
Tom
Tom, I really enjoy the simplicity of a rangefinderless camera - my daily carry for almost five years when I worked in downtown Chicago was a nice Retina Ia stoked with XP2. Collectors be damned!
I became very proficient in estimating range with that camera...
Ken, I`ve always wanted to try out a late 1920`s Leica I out, I`ve never worked with a rangefinderless Leica that would be a new and different approach to things
Tom
The body showed up today - very, very nice. I'm about 99% sure it's going to be an early (A36) 3.5cm Summaron of the same vintage as the body and a SBLOO.
.. and that's what it is. A clean 1952 vintage Summaron is on the way, and I'm working on a SBLOO finder.
Finally managed to get out and test the If and Summaron at lunch today. I'm happy - the body functions property and the lens is a gem. I definitely need a hood, though!
Totally unexciting test shots:
