Help me pick a Maxxum
CliveC
3:09 PM
Toronto, Canada
I was just gifted with a few Minolta lenses (A-mount I believe?) along with a Maxxum 300si.
I find the camera borderline unusable: I've never seen a SLR hide so much information from its user.
I did get some glass as well, nothing groundshaking, but a 50mm f/1.7, a 70-210mm f/4 and what I assume to be the kit 35-70mm f/3.5-4.5. Aside from the 70-210, plastic galore.
I'm looking to pick up a better body for less than $100. I was considering a Maxxum 7, but they're still up there in price. Am I correct that I should be looking for a 600si then? Any opinions about the Maxxum 5?
I can't speak for a Maxxum 5 but I'm quite happy with the UI of my Maxxum 70. Just a tad on the small side for my hands though.
I think it maybe one of the last film SLR bodies offered by Minolta. It can be easily mistaken for a DSLR.
In the Maxxum pedigree, the 9 series (900, 9000, 9) are the top tier. The 9 is the last model made. There are even some 9 available of handling lenses with the silent motor technology. It will take the Sony Zeiss SSM lenses. The 7 series is the second tier (700, 7000, 7). The 7 was releases after he 9. I have not used either, but I believe the it has more feature than the 9. SSM (silent motor technology) was not made available on the 7. All other series are inferior to these two.
www.dyxum.com is a forum of all things dynax/Maxxum (and Sony). Pay it a visit. It is close second to this site in terms of friendly advise.
When I was looking for one I decided to get a 5 because it was one of the few that would fire with an m42 adapter without a complicated button procedure at turn on. I cannot find the table listing this currently, but it's out there. I
It's hard to beat a 700si. I now have two of them, both in beautiful condition. I'm sure I paid well under $100 for each. Every feature you could possibly want; fantastic cameras, highly recommended!
Glen
I tried to give two Dynaxes away last year, after trying to sell them cheap for several weeks, only found a taker for one.. So people are actually paying for these now? Could anybody give me a hint to what a 7000i + 135/2.8 would be worth?
7 is the killer camera, even for today's standards..it can even write shooting details on your film...600si is my favourite due to all the external knobs, very intuitive to use
I'm not quite sure what you want in a camera although your comments about plastic and kit lenses might be clues. FWIW, the idea of kit lenses hadn't occurred to anyone when the Minolta range of AF SLR's appeared.
You might find, however, a lot of useful information about the cameras here:
http://en.wikipedia.org/wiki/Minolta_Alpha
FWIW 2, I've had the 7000 since it was new and am still pleased with it, even more so now I've the adapter for AA's...
FWIW 3, the cheap and useful 7000i might let you play with the lenses and save a lot of cash as they seem to give them away for 99p on ebay these days.
Regards, David
I think first and foremost I'm looking for something reliable, with no Achilles heel. I noticed that Minolta sent with some gimmicks somewhere in the 1990s with those add-in cards (for the 700si I believe?), so I'm looking to avoid those.
Hi Clive, I don't believe that the 700si used the cards, in any event, they are not required for the camera to operate at 100%. Minolta used them instead of having a sport or portrait function for eg. in the menu.
My original 9xi uses the cards, I've never had any cards in it and it has never impeded the function of it at all.
Get a 700si, you'll love it.
Andrew.
That 70-210/4 is lovingly called the Beercan and has a cult status. It is good lens.
That 50/1.7 is a prime, and a good one. The 35-70/3.5-4.5 isn't considered to be that good. If you want more information on these and other A-mount lenses, take a look over at dyxum.com, especially the lensdatabase. If you want information about bodies, look at mhohner.de.
The 700si uses cards, the 800si basically is a 700si with the cards build in. These are nice cameras and some tweaks. It might be the best bang in old Minolta AF cameras.
The 600si was the testbed for the user interface of the 7 and 9 cameras. It is considered slow, it used to have cult status but that seems to have worn off. It wouldn't be on my shortlist.
My shortlist:
9000: first pro autofocus camera and only AF camera with manual advance. Old, slow AF, but built like a tank and with its own website: 9000.org
9xi: maybe not for someone starting with Minolta as the interface is weird. But great build! I long graved for one, but I recently picked up a 7xi with the same weird interface.
700si/800si: good semipro bodies, with the edge to the 800si because you have everything you need in camera and it has the best build-in flash of any SLR/DSLR ever build.
7: great camera, but a bit gimmicky. Good AF, SSM support, supports modern flashes, it is the one to go for if you want to move to digital at some point.
9: it is the best SLR ever built. Period. Well, IMHO and YMMV. But it is a great intuitive camera and it is better then the Canon 1v. The only downside I can think of is that most of them don't support SSM lenses. If you want something metal, modern and indestructible this is the one!
5: if you want something small with all the whistles this is the one. It does SSM and supports modern flashes. It is plasticky though!
4: like the 5, but beside being plasticky it has a plastic mount 😱 but it does everything and it costs next to nothing.
I don't know what you're willing to spend, but the 9 or 7 seem the best choices to me. If you want something small and light, the 5 (or a 60/70) are the best choices. If you want a great bang, the 700si/800si are the ones. And if you want to go old skool, get the 9000!
Edit: i should learn to read! You stated $100,-..... Pick up a 700si/800si if you want semipro or a 5 (or 60/70) if want something with SSM capability!
Just to follow up, I just pulled the trigger on a 600si on eBay. Less than $30 +shipping and apparently the only issue is that the grips are sticky. I guess I'll see...
I'm still keeping an eye out for the 7, but they don't come around all that often it seems.
