Help please - frustrating Vuescan and transparency film ...
dmr
Registered Abuser
6:13 PM
I have a 14 year old K-M Scan Dual IV, which has been more or less working fine for all of those years. I used the stock scanning software until my old media PC died, and then switched to Vuescan since it runs on Windows 7.
It's worked more or less fine until this morning. I've scanned negatives and slides with it and it's been more or less foolproof.
However, this morning (I'm off today) I'm trying to scan my first roll of the new Ektachrome 100, which I processed last night. Since I don't project slides, I'm trying to scan the unmounted transparency film using the 6-frame carrier normally used for negatives. I set the media to "Slide Film" on the Input tab as in the screen shot below.
I'm having two issues:
1. No matter what I try, it insists on scanning as a NEGATIVE to the .tiff file! If I use Gimp and invert the colors they look more or less normal, but I would think it would be better to scan as a positive. When I open up the Color tab as shown in the second screenshot below, it gives me options for film brand and type and such, but no matter what I try I can't seem to coax it into any transparency film type and I think that has something to do with my issue. :(
2. On the Input tab I have Number Of Samples set to 2 and Multi Exposure checked. For frame 2, it behaves as expected, and does two separate passes as shown (as pass 2) in the screenshot, but for some reason on frame 1 it only does one pass. :(
I know we have some Vuescan jocks on here, and hopefully somebody knows what is going on.
Any suggestions?
Anyone see anything wrong that I may be doing?
Thanks in advance, gang! :)
The Windows version is different than my Mac, but, under input options, is professional or advanced available rather than standard?
Under color, are Kodak transparency film options available, rather than generic?
Can we see a screenshot of output settings?
To sounds like a bug from an internal contradiction. Short version. Contact Ed Hamrick.
Details.
Following my experience, Ed Hamrick will stand behind his software provided:
- your question is concise
- your question is clear
- your question is properly documented.
Delete vuescan.ini to start from a clean state. Perform all the steps that lead to issue1. exit vuescan. Save the log file (your actions) and vuescan.ini (the state of options, etc).
Delete vuescan.ini again and repeat the above for issue2.
Send all four files with concise explanations to Ed Hamrick.
Does your scanner “read” which carrier has been inserted and then pass that information to the software? My KM MultiPro does, at least with SilverFast. Maybe the same happens with Vuescan.
Thanks.
I would **SWEAR** I had it set to "professional", but missed it, even on the screenshot. (Am I turning prematurely blonde?) :)
I guess I should follow the prompts and upgrade. I am somewhat shy about upgrading anything, having been burned by things breaking over the years with no convenient way of backing out.
Yes, I assume it reads the carrier. It knows there are 6 frames and not 4.
I'll give both of them a shot and try again tomorrow afternoon.
Worst case, email Ed Hamrick. He's *personally* replied to two of my emails. Truly an amazing one-person operation, the guy deserves a place in the software Hall of Fame as well as the customer service one.
Thanks.
But I think it also “knows” negatives or transparencies.
Thanks.
But I think it also “knows” from which carrier is inserted that you are scanning negatives or transparencies.
I know this thread is a week old but there is an anomaly in the screen shots. If you select input mode:Transparency, and Media:Slide film, in the input tab, then your options in the color tab should only be Slide vendor:Generic or Kodak, Slide brand:Color, Slide type:Slide.
I may be that you have not selected Slide but rather Media:Color negative.
