knodd
Hello,
I'm pretty new to film developing, and i have this roll of tri-x (exposed at iso 400) which i have high expectations of, and i really don't wanna screw up. i'm quite sure the timing should be 6mins at 20 degrees c, but i'm not sure what method of agitation i should use, i seem to be getting different things from different sources:
1) on the back of the tmax dev bottle it says: 5 seconds of vigourous agitation (5 inversions in 5 seconds) every 30 seconds
2) digitaltruth.com: 30 seconds of continuous agitation followed by 10 seconds of agitation every 30 seconds (3 inversions in 10 seconds)
3) the local film guru at the film supply shop: 3 inversions every minute (for high grain / high contrast) or 1 inversion every 30 seconds (for low contrast)
I'm really confused as to which method to use, was hoping for some help and advise! Thanks in advance!
Shaun
Shaun
