Help! Regarding Rewind lever on M6
Harrison
1:00 PM
Hello all,
Just as i was finishing off a roll of film a few minutes ago on my M6TTL, i went to rewind the film. I noticed that the screw holding the lever on the front of the body had loosened quite a lot. This seems to have caused the lever to turn the opposite way now- it still 'rests' downwards, but turns clockwise, as to be 180 degrees from the little 'R'.
Should i loosen the screw to the same extent that it was already at and try to fix this? Or should i consult a technician about it?
Thanks in advance,
- Harrison
