Hi-speed T-Max 3200, Delta 3200, or ?
kzphoto
7:49 AM
I love the look I get with TMY-2 and I would like to try some of the higher speed films, but I haven't used them in ages. Last I remember, the T-Max 3200 was super grainy and the Delta 3200 was low contrast (developed in D-76.)
Just curious as to what people are using these days and what kind of results you're seeing? I'd be shooting mainly indoors / outdoors at night, wanting a 1600 - 6400 speed film. Medium contrast and grain kept to a minimum.
Try the Tmax3200 in the Tmax Developer. It's not as grainy as with other developer. Soup it at the lower temperature using a 1:4. I have few samples somewhere. Will try and locate them. I've never tried Delta3200.
TMax3200 @6400 in TMaxDev. 1+4
Don't expect anything in the shadows... ;)
Either of them in Tmax Developer. I prefer Delta 3200 slightly, but Tmax 3200 is great too. Use Tmax Developer, for both films. They SUCK in D-76. BAD. Xtol is merely decent, but not as nice as Tmax Developer for Tmax 3200; I have not tried it for the Ilford film.
Delta 3200 at EI-3200
Delta 3200 at EI-1600
Tmax 3200 at EI-1600
I've had very nice results with T-Max 3200 at 800 or 1600 in XTOL 1:1. It works alright at 3200 too, but you do begin to lose a noticeable amount in the shadows when exposed like that.
I've also heard good things about T-Max dev, DD-X, and Microphen with these films.
These are all shots on T-Max 3200. If you look in the tags, you can see what I rated it at (EI 800, 1600, etc.):
http://www.flickr.com/photos/tgray1/tags/p3200tmz/
Tmax p3200 in Tmax developer (stock).
P3200 is good but but would like to push Neopan 400 ($2 at recent deal) for economical reason.
Chris ... I really like that Funnel Cake stand shot in Delta 3200... did you do that in Tmax or DDX?
