Holga 6x12 mod
OlivierAOP
medium format
11:13 PM
Toronto
Here's another DIY 6x12 camera. Holga 120WPC body with pinhole assembly removed and front + film gate opened up. 3D-printed interchangeable lens mount.
Currently testing a 90mm f/5.6 Topcor, planning to adapt a 65mm f/7 Topcor and a Schneider 135mm f/8 Repro-Claron. DIY reverse Galilean finder @ 0.5 magnification with interchangeable masks. It *almost* covers the 65mm FOV.
Apart from some backing paper and development issues everything seems to work. Not an everyday camera but I like the look of medium format. The Topcor is not bad at all for a 6x9 lens with movements.
DSCF7402 by Olivier, on Flickr
DSCF7499 by Olivier, on Flickr
SIM00414-1 by Olivier, on Flickr
Tested the 65mm and 135mm. Poor photos but it seems to work. Swapped lenses mid-roll in a darkroom. All hand-held at f/22-32, 1/125, ISO 400. 135mm shots were likely out of focus, I'll have to check the calibration.
L to R: 90mm, 65mm, 125mm
DSCF7507 by Olivier, on Flickr
135mm
SIM00449-1 by Olivier, on Flickr
65mm
SIM00452-1 by Olivier, on Flickr
Edit. Figured out where I messed up the focus scale on the 135mm lens. Also tentatively fixed the lateral vignetting when using that lens.
